Apr 14, 2022
06:50 PM
Apr 14, 2022
06:50 PM
Hello.
<Test Report>
<Antenna Datasheet>
Why is the Peak Gain different?
Thanks and Best regards.
Glenn.
Labels
AIROC™ Bluetooth
09:21 PM
Apr 14, 2022
09:21 PM
It should be B4844/B4844-R. The datasheet is as follows. You can use either of them based on your application.
https://media.digikey.com/pdf/Data%20Sheets/Antenova/B4844_B4844-R_PS_Mar-2016.pdf
09:21 PM
Apr 14, 2022
09:21 PM
