I have custom HW with a CYBT-483039-02 module. I have built the LE_Beacon demo with Modus Toolbox and downloaded it to my CYW920719B2Q40EVB evaluation kit and it seems fine. I tried downloading it to my custom hardware over the HCI UART using the protocol described in the AIROC HCI Firmware Download document: I put the device into recovery mode, send a reset command, send the minidriver, erase the flash, send the SS section, send the DS section, send the launch command. For all these commands the device returns the expected response. But after the launch (or after a reset) my iPhone does not detect the expected CY BEACON or any other new bluetooth devices and the peripheral UART does not output the expected tracelog messages.
Thanks, Norm
Hi @ncampbell ,
You are using the module in the controller mode (with external host). So in this case, you have to download an empty application in the module, and after sending reset, you have to send other HCI commands like "set local BDA", "visibility", "LE advertise" ,etc. Please refer the AIROC HCI protocol document. You shall find all this explained and all the commands and subsequent events in it.
Thanks and regards,
Advait Kulkarni
Hi Advait - I should explain the bigger picture. My goal is to use the CYBT as a BLE-midi server, and I have written a Modus Toolbox application that does that. It works on the evaluation kit. However it does not work on my custom hardware. But to keep things simple I downloaded the LE_Beacon demo since we know the application is correct. But I should be able to download my application (NOT an empty application) and expect it to operate as a Midi server, correct? I intend to use the peripheral UART to send the received Midi data to the MCU on the custom hardware. The HCI UART is not connected to the MCU - it's connected temporarily to a PC just so I can download the application.
Thanks, Norm
Hi @ncampbell ,
You are using the LE beacon application that has a support for CYW920719B2 chip, hence it is working on the eval kit however, the CYBT-483039-02 module is based on CYW20719B1 and it is no longer supported on MTB. Hence, it is not working. either you can use a chip that has a support for the latest stack version, or you may have to look for using the WICED studios, but the support for this environment is removed for infineon's bluetooth products.
Thanks and regards,
Advait Kulkarni.
I have to use the CYBT-483039-02 module. So I guess I have to use Wiced Studio. You say "support for this environment is removed" - what exactly does that mean? Is it possible to develop a BLE-Midi server using Wiced Studio? If so which version and where do I find it? Thanks.
Hi @ncampbell ,
The latest version of wiced studios does not have support for bluetooth and we are bot advised to suggest it to the customers. Moreover, there will be no technical support for any issue on wiced studio. Kindly go through the modules page of infineon https://www.infineon.com/cms/en/product/wireless-connectivity/airoc-bluetooth-le-bluetooth-multiprot... and let us knowif you can upgrade to any currently supported modules. Since you have the 20719B2 eval kit, you can look for a module based on this B2 chip.
Thanks and regards,
Advait Kulkarni
The module based on the B2 chip is not really available - no one has stock. I understand the latest Wiced Studio does not support bluetooth but is there an older version that supports the B1? Thanks, Norm.
Hi @ncampbell ,
I have asked our marketing team regarding providing the older wiced version, kindly give us some time and I will get back to you as soon as possible.
Thanks and regards,
Advait Kulkarni
