I want to convert my CYBT-4803056 module to EZ-serial but firmware as per knowledge base I downloaded the WICED_MOD_Prog_v1.5.19.102.zip but when opened I found it did not support CYBT-483056 board.
Please guide me how I can program this in CYBT-483056 board.
Thanks in advance.
Prasad
I fixed this issue by using chipload.exe from ModusToolbox. I created Empty SDK application and used Chipload.exe with parameters from this project. like minidriver and btp file references. By replacing CONFIG option with EZ Serial hex file.
Hello ,
Thanks for sharing your fix.
Anjana
