I am trying to use CYBT-353027-02 as a headset.
When I make a call on the phone I get a BTM_SCO_CONNECTION_REQUEST_EVT event.
In the event handler I call the wiced_bt_sco_accept_connection function but the connection is not established. After a few seconds I get a BTM_SCO_DISCONNECTED_EVT event.
Why?
How can I troubleshoot this issue?
/BR
Found the problem. I had the somehow managed to set wrong esco parameters,
Hello @oskla129
Can you please let us know what is the end application you are trying to implement ? Headset app should work as such , can you please let me know why you want to modify it with accept SCO connection API ?
Anjana
The end application is a headset.
I am using the example at https://github.com/Infineon/mtb-example-btsdk-audio-headset as starting point.
In that example wiced_bt_sco_accept_connection was called on SCO connection request so, I assumed that was the correct thing to do.
Is it not necessary?
Oskar
