user_2208511
06:31 PM
- Email to a Friend
Hello:
Here are 2 questions about CYBT-243053-02 module:
1. Except pin28~31 can be use as UART interface, which pins can be the second UART?
2.Does P1 pin can be set as a PWM pin,output PWM signal?
thanks!
Labels
AIROC™ Bluetooth
10:48 PM
- Email to a Friend
Hi @user_2208511 :
1. Any PIN can be assigned for the second UART.
2. Yes.
All the setting you can do it in the Device Configurator GUI tool in Eclipse IDE for ModusToolBox.
Best Regard,
Colin
user_2208511
07:24 PM
- Email to a Friend
another question
Which GPIOs can be set as SPI interface?need to connect to SPI flash. thanks!
09:39 PM
- Email to a Friend
Hi @user_2208511 :
It's same with UART setting.
You can assign any GPIO as SPI port in the Device Configurator GUI tool in Eclipse IDE for ModusToolBox.
Colin
