Good day!
I have CYBT-353027-EVAL and work in ModusToolbox. I read CypressAcademy docs. I try to do ch04a_ex01_ble exersice in WBT101-04A-BLE-Basic.pdf. There are NO app_gatt_get_value and app_gatt_set_value function implementations. The functions with such names are not even used in HelloSensor example => so I can't understand how to use lines of code available in pdf to make all things work right.
Could someone share these functions? Are there any working zips with ch04a_ex01_ble and other exercises from CypressAcademy docs available as a reference? Thanks!
Dobre
BLE
ispn:40232:1:0
l1:314:1:0
Hi @Dobre ,
key_ch04a_ex01_ble is already a completed working project. Are you getting any build errors when you compile this example? You should find the definitions of app_gatt_get_value and app_gatt_set_value in the below file
Bragadeesh
Hi @Dobre ,
Bragadeesh
