Good day!
I use CYBT-353027-EVAL. Work in ModusToolbox. In WBT101-04A-BLE-Basic.pdf (4A.4.1 Bluetooth Configurator) it is said how to use Bluetooth Configurator in new application (when trying Empty_BTSDK_App). This utility is useful to create GATT structure and I can get cycfg_gatt_db.c and cycfg_gatt_db.h in GeneratedSource folder. But what I can do if I try HelloSensor? Bluetooth Configurator utility offers me to create a new configuration and I don't have GeneratedFolder in template HelloSensor example. I would like to change GATT structure a little.
Any ideas? Thanks!
Dobre
BLE
ispn:40232:1:0
l1:314:1:0
The demo code is not generated from the bluetooth configurator. So you can't find the generated files and change it by bluetooth configurator. You may create your own application if you want to use it.
In the hello_sensor demo, the database is defined in parameter hello_sensor_gatt_database.
I would recommend to change the code directly if you only need change it a little.
In WBT101-04A-BLE-Basic.pdf page 16 is stated "... You should not modify the generated code by hand – any changes should be done by re-running the Bluetooth Configurator."
Is there any convenient way how to change GATT using Bluetooth Configurator? Thanks!
