The HOST_WAKE signal on the CYBT-413055 EVAL can be enabled via a vendor specific command.
How it ist possible?
You can use Cybluetool- https://community.cypress.com/t5/Public-Archive/CyBluetool-User-s-Guide/m-p/256195 to send the HCI commands to the module. Please check above link for details.
Hi @237_KGKT ,
Please check VSC set_sleepmode_param. Here you can use HOST_WAKE pin for setting HOST_WAKE_Active_Mode option.
thanks for the answer!
i'm just getting into cypress. i don't know much about the device and its features. I have a lot of question about this stuff
could you please explain this in more detail?
how can i check this VSC set_sleepmode_param
ModeToolbox version 2.3.0
Operating system: Window
Development board CYBT 413055 Eval
I would be glad for your quick response
