AIROC™ Bluetooth Forum Discussions
KeTa_1341526
10 solutions authored 5 solutions authored 100 replies posted
I would like to check if the following Modules support the [Channel Selection Algorithm # 2] function of LE Link Layer.
- CYBLE-343072-02 (CYW20835)
- CYBT-343052-01 (CYW20735)
- CYBT-343026-01 (CYW20706)
- CYBLE-416045-02 (PSoC6)
- CYBLE-012011-00 (PSoC4)
I recognized from the "ICS detail" of the BT SIG Listing that:
- CYBLE-343072-02 (CYW20835) : Support
- CYBT-343052-01 (CYW20735) : Support
- CYBT-343026-01 (CYW20706) : Not Support
- CYBLE-416045-02 (PSoC6) : Not Support
- CYBLE-012011-00 (PSoC4) : Not Support
Do you agree with me?
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hello @KeTa_1341526
You are correct with respect to BTSDK BLE chips such as - CYW20735 , CYW20835, CYW20719, CYW20819 supports CSA #2 . CYW20706 does not support.
Regarding PSoC BLE device I will double check and update you.
Anjana
AnjanaM_61
Hello @KeTa_1341526
Anjana
AnjanaM_61
Hello @KeTa_1341526
I checked internally  and confirmed that CSA #2 is not supported on PSoC LE devices
Anjana
Hi Anjana,
Thank you for your update.
I understand it.
