wenchilo
Level 4
Level 4
First like received 25 replies posted 25 sign-ins
Hi, I am developing CYBT-343026 with modus2.4. But I have meet some problems that I can search the eval board"spp test" on my SPP app but I can't connect to the eval board. I have tried three different apps on two smart phones but the result is still the same. I am using sample code RFCOMM_Serial_Port and the following are my log and air log.
Please try to change the SPP_RFCOMM_SCN to 1 as follows to see if the connection can be successful:
#if defined (CYW20706A2)
#define SPP_RFCOMM_SCN 1
#else
#endif
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
The spp demo works fine on the WICED SDK per my test.
There may be some change in the btstack on modus which causes the problem.
Could you use the WICED SDK for your development? You can use the WICED 6.2.1:
https://www.infineon.com/cms/en/design-support/tools/tools-archive/wiced-studio-archive/#!documents
wenchilo
Level 4
Level 4
But I need to use IAP. Is WICED able to develop IAP?
wenchilo
Level 4
Level 4
Cause we have apply and  get mtb-example-btsdk-pro-iap2.zip. And all the guide is for all modustoolbox. Do you have a guide for how to import iap into wcied IDE?
#else
#endif
