wenchilo
Level 4
Level 4
First like received 25 replies posted 25 sign-ins
Hi, I am using CYBT-343026 and ModusToolBox to develop my project. I use SPP sample code to build and download successfully. But when I use a SPP app on an android phone. I can search "spp test" on the app but the connection always fail when I try to connect it. I didn't modify the code and the situation didn't appear when I use WICED. What could be problem.
By the way, my Modus version is 2.4.0. And I have import IAP2 SDK.
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Hello @wenchilo
Is this issue solved for you?
can you please confirm if you are using 343026 EVAL board or custom board?
I tried the code example & it is working fine at my side.
Can you try using some other mobile phone and SPP peer app ?
Anjana
wenchilo
Level 4
Level 4
I have create a project without IAP and the problem still exist. So it seems that the problem isn't cause by IAP.
AnjanaM_61
Hello @wenchilo
Can you please let us know which peer device or app you are using?
Can you please share any logs on disconnection ?
Are you using CYBT-343026 EVAL board or custom board ?
Anjana
1 . I have tried two apps on two different cellphone. One is SPP藍芽串口 on Redmi k4, the other is 藍芽串口 on Galaxy A8.
2 . It's strange cause that I can't get any log from puart. As the HCI the following log :
19 03 00 07 00 01 06 04 03 0B 00 13 19 03 00 07 00 00 0F 04 00 01 06 04 19 03 00 07 00 00 05 04 00 0B 00 16 <>
19 03 00 0D 00 00 04 0A 90 88 4F 04 46 88 0C 02 5A 01 19 03 00 0B 00 01 09 04 07 90 88 4F 04 46 88 00 19 03 00 07 00 00 0F 04 00 01 09 04 <>
19 03 00 0B 00 00 12 08 00 90 88 4F 04 46 88 00 19 03 00 0E 00 00 03 0B 00 0C 00 90 88 4F 04 46 88 01 00 19 03 00 06 00 01 1D 04 02 0C 00 19 03 00 0F 00 03 0C 20 0A 00 06 00 01 00 0A 02 02 00 02 00 19 03 00 07 00 00 0F 04 00 01 1D 04 19 03 00 06 00 01 1F 04 02 0C 00 19 03 00 0B 00 00 0C 08 00 0C 00 0B 1D 00 EC 27 19 03 00 07 00 00 0F 04 00 01 1F 04 19 03 00 06 00 01 7B 0C 02 0C 00 19 03 00 0B 00 00 0E 08 01 7B 0C 00 0C 00 B8 0B 19 03 00 08 00 01 0D 08 04 0C 00 05 00 19 03 00 09 00 00 0E 06 01 0D 08 00 0C 00 19 03 00 08 00 01 37 0C 04 0C 00 00 7D 19 03 00 09 00 00 0E 06 01 37 0C 00 0C 00 19 03 00 06 00 00 1B 03 0C 00 05 19 03 00 0A 00 00 20 07 90 88 4F 04 46 88 01 19 03 00 0F 00 02 0C 20 0A 00 06 00 01 00 0A 02 02 00 02 00 19 03 00 11 00 03 0C 20 0C 00 08 00 01 00 0B 02 04 00 02 00 01 00 19 03 00 08 00 00 13 05 01 0C 00 02 00 19 03 00 08 00 00 1C 05 00 0C 00 43 08 19 03 00 15 00 02 0C 20 10 00 0C 00 01 00 0B 02 08 00 02 00 00 00 B8 00 00 00 19 03 00 0F 00 03 0C 20 0A 00 06 00 01 00 0A 03 02 00 03 00 19 03 00 11 00 02 0C 20 0C 00 08 00 01 00 02 03 04 00 01 00 4A 00 19 03 00 15 00 03 0C 20 10 00 0C 00 01 00 03 03 08 00 42 00 4A 00 00 00 00 00 19 03 00 15 00 03 0C 20 10 00 0C 00 01 00 04 04 08 00 4A 00 00 00 01 02 40 00 19 03 00 19 00 02 0C 20 14 00 10 00 01 00 0B 03 0C 00 03 00 00 00 82 00 00 00 00 00 00 00 19 03 00 08 00 00 13 05 01 0C 00 02 00 19 03 00 15 00 02 0C 20 10 00 0C 00 01 00 04 04 08 00 42 00 00 00 01 02 00 04 19 03 00 17 00 03 0C 20 12 00 0E 00 01 00 05 04 0A 00 4A 00 00 00 00 00 01 02 00 04 19 03 00 13 00 02 0C 20 0E 00 0A 00 01 00 05 04 06 00 42 00 00 00 00 00 19 03 00 08 00 00 13 05 01 0C 00 02 00 19 03 00 1D 00 02 0C 20 18 00 14 00 42 00 06 00 00 00 0F 35 03 19 11 01 03 F0 35 05 0A 00 00 FF FF 00 19 03 00 61 00 03 0C 20 5C 00 58 00 4A 00 07 00 00 00 53 00 50 35 4E 36 00 4B 09 00 00 0A 00 01 00 01 09 00 01 35 03 19 11 01 09 00 04 35 0C 35 03 19 01 00 35 05 19 00 03 08 01 09 00 06 35 09 09 65 6E 09 00 6A 09 01 00 09 00 09 35 08 35 06 19 11 01 09 01 02 09 01 00 25 0A 53 50 50 20 53 45 52 56 45 52 00 19 03 00 11 00 02 0C 20 0C 00 08 00 01 00 06 05 04 00 42 00 4A 00 19 03 00 11 00 03 0C 20 0C 00 08 00 01 00 07 05 04 00 42 00 4A 00 19 03 00 08 00 00 13 05 01 0C 00 02 00 <>
19 03 00 07 00 01 06 04 03 0C 00 13 19 03 00 07 00 00 0F 04 00 01 06 04 19 03 00 07 00 00 05 04 00 0C 00 16 <>
3 . I have tried both EVAL and custom board and the results are the same.
1 . I have try SPP藍芽串口  on Redmi k40 and 藍芽串口 on Galaxy A8. And the results are the same.
2 . It's strange that I can't get any log from puart. But I got some log from hci uart:
3 . I have tried both eval and custom board, and the results are the same.
Thanks you
Thanks you
Thanks you
Thanks you
Thank you
wenchilo
Level 4
Level 4
wenchilo
Level 4
Level 4
wenchilo
Level 4
Level 4
Thanks you
AnjanaM_61
Hello @wenchilo
Anjana
