Hi, I'm develop with CYBT-343026 on modus2.4. And I am trying to combine SPP abd iAP. Bur I found it seems that wiced_bt_sdp_db_init can only init once. How can I initial both
Hello @wenchilo
You should not call wiced_bt_sdp_db_init multiple times. If you want to use more than one profile in a project, you should call wiced_bt_sdp_db_init once with different SDP records added w.r.t each profiles in the SDP database. For example, refer the example projects in MTB like watch .
Anjana
Hello @wenchilo
Anjana
