The datasheet of CYBT-343026-01 says "Integration of this module into a final product does not require additional radio certification".
Is final product approval from SRRC necessary if the product needs BT connection via CYBT-343026-01 to provide its main functionality?
In other words, is it necessary to get final product approval from SRRC if a product does *NOT* have any input interface and can only function by receiving commands from external input source, such as wirelessly connected smart phones?
That's the case with Taiwan NCC. Is it the same case with SRRC?
I appreciate your help on this
You can use the certification for the module in your product. You don't need to do the certification again.
Could someone help me here? Here's what I really want to know.
Are there cases when SRRC approval is required by final product basis even fully approved module like CYBT-343026-01 is installed?
I re-checked the problem internally. Generally, it is not needed to re-certify the end product for IOT usage. But if your end product is a special usage, the certification is also needed.
It is better for you to check it with SRRC for a certain product.
