I'm trying to build CE216767 - PSoC6 MCU with Bluetooth Low Energy (BLE) Connectivity Bootloader, which I just downloaded from the tool.
I'm using PSoC Creator 4.3 with PDL 3.0.3
When I build the project I get the following errors:
- Build error: region RAM overflowed with stack
- Build error: region `ram_app0_core0' overflowed by 4560 bytes
I tried adjusting the size of the RAM region in the linker scripts for the CM0 and CM4 cores and then running clean/build, but this seems to have no impact. I'm kind of lost here, I'm not very knowledgeable with linker scripts. Help is appreciated.
Please refer to the attached code example project. Please increase the size of ram_app0_core0 in the linker scripts.
Please let me know if this works. If you are still facing the issue, then please share your project for testing at our end.
P Yugandhar.
P Yugandhar.
When I try to build app001 in the workspace you sent, I get an error saying that it is missing dfu/cy_dfu.h.
I attached the project I am trying to build. I tried editing cy8c6xx7_cm0plus.ld and cy8c6xx7_cm4_dual.ld to increase the size of RAM, which appears to be aliased to ram_app0_core0. This change is having no effect for me, though.
