AIROC™ Bluetooth Forum Discussions
stiko
First question asked Welcome!
Hello! I am using this example https://github.com/Infineon/training-modustoolbox-level3-bluetooth/tree/master/Type1/Projects/key_ch... with CY8CPROTO-062-4343W. My problem is that the program goes into an infinite loop when I use the cyhal_system_delay_ms function. The timers don't work either. How could I solve this problem.
Tushar_b
50 sign-ins 25 replies posted First like received
Can you share the steps or files to recreate the same at our end this will definitely help us to examine the issue.
We tested the example project and working as expected.
Tushar
