Mar 21, 2023
12:35 PM
Mar 21, 2023
12:35 PM
Hi everyone!
I have been working with the following IC CYBLE-224116-01, but I would like to know if you can recommend a programmer for this IC.
01:56 AM
Mar 23, 2023
01:56 AM
Hi @TARRE060912
If you are using the eval board then you can follow this setup mentioned in this below link
if using IC you can use the datasheet and this below link for more information.
let me know if this helps
Thanks & Regards
Pratiksha V
01:56 AM
Mar 23, 2023
01:56 AM
Hi @TARRE060912
Thanks & Regards
Pratiksha V
