I'm using CYW20706 to develop a Bluetooth speaker, with CYBT-343026-EVAL.
I had a problem with using Wiced Studio for a2dp sink app for CYBT-343026-EVAL on post Solved: Re: CYBT-343026 I2S data output voltage level prob... - Infineon Developer Community
Now I'm working with ModusToolbox and a2dp sink app for CYW920706WCDEVAL by following the suggestion on the previous query.
Update
The app supports CYW920706WCDEVAL. We can port the app to CYBT-343026-EVAL and use it. CYBT-343026-EVAL also has the same chip (CYW20706). The difference is between the BSP - Hardware configurations.
But still don't know what I should change to port this app to work.
Please let me know what parts I should change this app to work on CYBT-343026-EVAL.
You may have to take care of the Board specific configurations such as GPIOs, UART, LEDs, Buttons, etc. Major Bluetooth functionalities will be working without any problems since the silicon is the same. Each kit has separate Board specific packages which have such configurations/declarations.
Eg.https://github.com/Infineon/TARGET_CYW920706WCDEVAL
https://github.com/Infineon/TARGET_CYBT-343026-EVAL
You can get the a2dp_sink app and upload it for CYBT-343026-EVAL and make appropriate changes wherever you see problems.
https://github.com/Infineon/mtb-example-btsdk-audio-a2dp-sink
-Dheeraj.P.K
-Dheeraj.P.K
Hi, Dheeraj
Thanks for the information.
I've changed some pin settings for CYBT-343026 in 'mtb_shared -> wiced_btsdk -> dev-kit -> bsp -> TARGET_CYW920706WCDEVAL.
But I still get a problem working it correctly.
Problem :
I've tried to communicate with the board through teraterm with uart function in board, but the words get cracked. What I'm thinking is a baud rate mismatch but I can't solve it after changing baud rate setting in wiced_platform.h (I get warning message when I build the application after changing the value)
I'll attach the capture of the list down below, please let me know if there's something I need to change or wrong.
1. Teraterm setting, message I get from board
2. Warning message while building after changing baud rate value
3,4. Changes I made in bsp to work on CYBT-343026-EVAL in each file.
platform.c
wiced_platform.h
Ted
Update:
I guess the application is not imported properly. Instead of changing the BSP, please download the application from the github and import to the MTB workspace locally. For that you may need to change the target as below.
# default target
TARGET=CYBT-343026-EVAL
SUPPORTED_TARGETS = \
CYW920706WCDEVAL \
CYW9M2BASE-43012BT \
CYW920721M2EVK-01 \
CYW920721M2EVK-02 \
CYW943012BTEVK-01 \
CYW955572BTEVK-01 \
CYW920721M2EVB-03 \
CYBT-343026-EVAL
FYI.
