Using MTB 2.4, I would like to use this example:BLE GATT Server demo to MQTT
But using CY8CPROTO-063-BLE (CYBLE-416045-02), with PSoC 6 BLESS https://github.com/Infineon/bless
I see a WICED version of FreeRTOS BLE, but not a BLESS one.
What would be involved in making these work together?
Does it seem feasible, or even better, is there an effort in progress already to add support for this device?
CY8CPROTO-063-BLE has PSoC 63 part that has BLE sub system and it uses the CY BLESS library.
Currently, Amazon FreeRTOS only supports AIROC based platforms that support WICED-based stack. We don't have WICED-based stack for BLESS (P6-BLE). It'll be available by April 2022.
P Yugandhar.
Hi @Panometric ,
Have you checked the PSoC 6 BLE throughput example that uses FreeRTOS?
https://github.com/Infineon/mtb-example-psoc6-ble-throughput-freertos
Bragadeesh
Yes, that example uses BLESS API. "ble_*()" and FreeRTOS. But that is not the question.
On top of the OS, FreeRTOS has a BLE Library that the demo app uses. https://docs.aws.amazon.com/freertos/latest/userguide/freertos-ble-library.html
Infineon's Git has the source here:
https://github.com/Infineon/amazon-freertos/blob/034588cc335fdf3a2f8a3e77068e266888237a17/demos/ble/...
The BLE interface is abstracted here:
But that is where I lose the trail...
Hello @Panometric
Are you looking for using MQTT protocol on P6 BLE ? Can you please clarify your exact requirements ?
@AnjanaM_61 , yes I want to use the MQTT bridge / proxy with AWS. The link above shows:
"This demo demonstrate the FreeRTOS GATT server by sending a simple counter value to a mobile device application coded against the iOS and Android device SDK for BLE and FreeRTOS. The libraries in the iOS and Android SDK will seamlessly publish the messages to the cloud through MQTT. The mobile application demo can be found in the same iOS and Android SDK."
P Yugandhar.
We had the stack in testing but it won't be provided to the customers.
P Yugandhar.
