AIROC™ Bluetooth
Panometric
Level 5
10 solutions authored First comment on KBA First comment on blog
Level 5
Using MTB 2.4, I would like to use this example:BLE GATT Server demo to MQTT
But using CY8CPROTO-063-BLE (CYBLE-416045-02), with PSoC 6 BLESS https://github.com/Infineon/bless
I see a WICED version of FreeRTOS BLE, but not a BLESS one.
What would be involved in making these work together?
Does it seem feasible, or even better, is there an effort in progress already to add support for this device?
Yugandhar
Moderator First comment on blog 750 replies posted 500 replies posted
CY8CPROTO-063-BLE has PSoC 63 part that has BLE sub system and it uses the CY BLESS library.
Currently, Amazon FreeRTOS only supports AIROC based platforms that support WICED-based stack. We don't have WICED-based stack for BLESS (P6-BLE). It'll be available by April 2022.
P Yugandhar.
BragadeeshV
Moderator First question asked 1000 replies posted 750 replies posted
Hi @Panometric ,
Have you checked the PSoC 6 BLE throughput example that uses FreeRTOS?
https://github.com/Infineon/mtb-example-psoc6-ble-throughput-freertos
Bragadeesh
Panometric
Level 5
Level 5
@BragadeeshV  could you follow up?
Panometric
Level 5
Level 5
Yes, that example uses BLESS API. "ble_*()" and FreeRTOS. But that is not the question.
On top of the OS, FreeRTOS has a BLE Library that the demo app uses.  https://docs.aws.amazon.com/freertos/latest/userguide/freertos-ble-library.html
Infineon's Git has the source here:
https://github.com/Infineon/amazon-freertos/blob/034588cc335fdf3a2f8a3e77068e266888237a17/demos/ble/...
The BLE interface is abstracted here:
https://github.com/Infineon/amazon-freertos/tree/034588cc335fdf3a2f8a3e77068e266888237a17/libraries/...
But that is where I lose the trail...
AnjanaM_61
Moderator First comment on KBA 5 questions asked First question asked
Hello @Panometric
Are you looking for using MQTT protocol on P6 BLE ? Can you please clarify your exact requirements ?
Panometric
Level 5
Level 5
@AnjanaM_61 , yes I want to use the MQTT bridge  / proxy with AWS.  The link above shows:
"This demo demonstrate the FreeRTOS GATT server by sending a simple counter value to a mobile device application coded against the iOS and Android device SDK for BLE and FreeRTOS. The libraries in the iOS and Android SDK will seamlessly publish the messages to the cloud through MQTT. The mobile application demo can be found in the same iOS and Android SDK."
Panometric
Level 5
Level 5
@BragadeeshV  or @AnjanaM_61 , any follow up?
Yugandhar
P Yugandhar.
Panometric
Level 5
Level 5
@Yugandhar is there an early adopter / beta for that?, I would like to try ASAP.
Yugandhar
We had the stack in testing but it won't be provided to the customers.
P Yugandhar.
