I can not select any option other than "Eclipse IDE for ModusToolBox" (grayed) in Project Creator V1.40.
I want to select Iar EWARM V8.x
Br
Joakim
Hi @Bollsta ,
Have you tried using the modus shell to setup EWARM8. This is described in section 7.4.2 of ModusToolbox™ 2.3 User Guide .
You can also specify the IAR toolchain and toolchain path in the makefile of your project as well as described in section 12 of knowledge base article KBA229177.
Hope this helps.
Hi @Bollsta ,
Hope this helps.
Hi @Bollsta ,
Glad the solution helped. Thank you for using Infineon products and please feel free to drop your queries in Infineon Developer Community again in case of any queries or issues regarding our products.
