galin
I am trying to start a BLE project using Modul Toolbox for chip: CYW20721 - QFN40 starting from CYW920721B2evk-03.
I only have the eval board CYW920721B2evk-02; when I import the example 'find me' and load it on the cypress eval board (CYW920721B2evk-02) I see in the app CySmart, advertised a BT device 'find me'.
We built an Eval board with QFN40 (without External Power amplifier - BT RF pin16 is routed to a chip BT antenna though a filter). I loaded (over Host UART) the example 'find me' for Cypress eval board CYW920721B2evk-03 and I was not able to see any advertisement (on CySmart).
Then I realized (in Device Configurator 2.1) that 'find me' example is using Low Noise/External Power Amplifiers. I don't have the schematic (or the actual Cypress Eval board CYW920721B2evk-03) to confirm if External amplifier is present ... but I don't have it on my custom eval board.
Should I uncheck the check box and recompile? Do I have to change anything in the project?
I already verified that (without success) ... meaning I don't see anything advertised in CySmart after I recompiled without External Power Amplifier.
I connected PUART pins to MiniProg4 UART pins and I can see the following log generated:
**** Find Me Profile Application Start ****
Unhandled Bluetooth Management Event: 0x15 (21)
Bluetooth Enabled (success)
Local Bluetooth Address: [20 72 1b 29 6b 21 ]
Advertisement State Change: 3
Advertisement started
Can someone provide me the schematic/PCB for board: CYW920721B2evk-03? Is this a Software problem or A Hardware problem? How can I debug this?
My custom Eval board has 24MHz crystal and all decoupling capacitors required for power rails.
Thank you,
galin
Charles_Lai
10 questions asked 250 replies posted 100 solutions authored
CYW920721B2EVK board is not available in the open channel currently. Please contact your local sales representative to order the samples. See:
https://www.cypress.com/documentation/development-kitsboards/cyw920721b2evk-02-evaluation-kit
Also, you can have several versions of ModusToolbox on a Windows 10 laptop. Using the latest version is preferred.
Charles_Lai
Since you can see logs given in PUART, I think the program was running successfully. That's a problem rather in hardware or configuration, etc.
You could apply for an EVB board at the Cypress Store.
galin
Hi Charles,
Thank you for your fast response.
I checked the link https://www.cypress.com/wireless-kits but I was not able to see the eval board: CYW920721B2EVK-03.
After more debugging (using printf) I am able to see that:
- on custom Eval board (with QFN40) we see function adv_led_update() is called with app_bt_adv_conn_state=1. The timer wiced_start_timer(&adv_led_timer, ADV_LED_UPDATE_RATE_MS); is enabled but will never fire (later on).
I will investigate more and let you know my findings.
Also I realized that I am using ModusToolbox 2.1.0 --> should I update to latest ModusToolbox? Can I have two ModusToolbox installed (on a Windows 10 laptop)?
Thank you,
Alin
Charles_Lai
