I'm trying to use SPI1 in master mode on a CYW920706WCDEVAL board to simultaneously send/receive data with another device.
The API documentation describes the wiced_hal_pspi_exchange_data(len, txbuf, rxbuf) function, which is forwarded to spiffyd_ExchangeData() in wiced_hal_pspi.h. However, it appears that function is not included in the SDK. A linker error is attached below.
-*- mode: compilation; default-directory: "~/code/intercreate/cyblu/io-fw/" -*-
Compilation started at Mon Feb 15 14:43:43
gmake -k build
CYW920706WCDEVAL.mk: ../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYW920706WCDEVAL/release-v2.8.0/CYW920706WCDEVAL.mk
/Users/andy/code/intercreate/cyblu/io-fw/build/CYW920706WCDEVAL/Debug/IO-evm.ld already present, use clean if it needs updating
Prebuild operations complete
Commencing build operations...
Initializing build: IO-evm Debug CYW920706WCDEVAL GCC_ARM
Auto-discovery in progress...
-> Found 20 .c file(s)
-> Found 0 .S file(s)
-> Found 0 .s file(s)
-> Found 0 .cpp file(s)
-> Found 0 .o file(s)
-> Found 15 .a file(s)
-> Found 166 .h file(s)
-> Found 0 .hpp file(s)
-> Found 0 resource file(s)
Applying filters...
Auto-discovery complete
Constructing build rules...
Build rules construction complete
= Building application =
Generating compilation database file...
-> ./build/compile_commands.json
Compilation database file generation complete
Generated 1 source file(s)
/Users/andy/code/intercreate/cyblu/io-fw/build/CYW920706WCDEVAL/generated/lib_installer.c already present, use clean if it needs updating
Building 21 file(s)
Compiling ext file spim.c
Linking output file IO-evm.elf
/Applications/ModusToolbox/tools_2.2/gcc/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: /Users/andy/code/intercreate/cyblu/io-fw/build/CYW920706WCDEVAL/Debug/ext/src/intercreate/spim.o: in function `wiced_hal_pspi_exchange_data':
/Users/andy/code/intercreate/cyblu/io-fw/../mtb_shared/wiced_btsdk/dev-kit/baselib/20706A2/release-v2.8.0/include/hal/wiced_hal_pspi.h:280: undefined reference to `spiffyd_exchangeData'
collect2: error: ld returned 1 exit status
gmake[1]: *** [../mtb_shared/core-make/release-v1.5.0/make/core/build.mk:528: /Users/andy/code/intercreate/cyblu/io-fw/build/CYW920706WCDEVAL/Debug/IO-evm.elf] Error 1
gmake[1]: Target 'build' not remade because of errors.
gmake: *** [../mtb_shared/core-make/release-v1.5.0/make/core/main.mk:414: secondstage_build] Error 2
gmake: Target 'build' not remade because of errors.
Compilation exited abnormally with code 2 at Mon Feb 15 14:43:43
ispn:38625:1:0
l1:314:1:0
Wireless
We could reproduce it our side.
Seems like the linker is not updated as you said. We will check with the dev team and get back to you.
-Dheeraj
-Dheeraj
The issue has been fixed by four software team and the fix will be available in the upcoming BTSDK (To be released in a month).
