Keep in slave role
wenchilo
First like received 25 replies posted 25 sign-ins
Hi cypress team,
I am work on spp sample code with CYBT-343026. And I want to keep my 343026 in slave, but sometimes there's a role switch that my 343026 become master. I have tride wiced_bt_dev_switch_role to switch it back to slave but it doesn't  work. What can I do to keep it in slave mode.
The API can work for BT configuration. Please set it as follows:
uint8_t  role;
        case BTM_ENABLED_EVT:
              role = wiced_bt_l2cap_set_desire_role(L2CAP_ROLE_DISALLOW_SWITCH);
            WICED_BT_TRACE("==== disable switch role=%d\n", role );
            role = wiced_bt_l2cap_set_desire_role(0x01);//slave = 0x01
            WICED_BT_TRACE("==== set desire role=%d\n", role );
AnjanaM_61
5 comments on KBA First comment on KBA 5 questions asked
Hi @wenchilo
Can you please let us know the peer device you are using?
What is the result of wiced_bt_dev_switch_role  API ? Where exactly you are using this API in your application code?
Anjana
wenchilo
1. The peer device is also CYBT-343026
2. I am not sure about the result of wiced_bt_dev_switch_role cause WICED_BT_CMD_STARTED and
WICED_BT_MODE_UNSUPPORTED are undefined, but I think it should be one of them.
3.I am using this api in rx callback, while I receiving a specific uart command
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Please try to use the following API:
* Function wiced_bt_l2cap_set_desire_role
* This function sets the desire role for L2CAP.
* If the new role is L2CAP_ROLE_ALLOW_SWITCH, allow switch on
* HciCreateConnection.
* If the new role is L2CAP_ROLE_DISALLOW_SWITCH, do not allow switch on
* If the new role is a valid role (HCI_ROLE_CENTRAL or HCI_ROLE_PERIPHERAL),
* the desire role is set to the new value. Otherwise, it is not changed.
* @param[in] new_role: New role value
* @return the new (current) role
uint8_t wiced_bt_l2cap_set_desire_role (uint8_t new_role);
wenchilo
Hi, can this API be called after making a connection, or do I have to choose the role before connection
wenchilo
I have tried calling wiced_bt_l2cap_set_desire_role before and after making a connection. But it still doesn't work.
wenchilo
I am not sure if wiced_bt_l2cap_set_desire_role works on bt cause the introduction says valid role including HCI_ROLE_CENTRAL or HCI_ROLE_PERIPHERAL but not master and slave.
uint8_t  role;
