- Email to a Friend
Hi,Communites,
We received a question from a customer regarding the CYBLE-212006-01.
The CYBLE-212006-01 supports Extended Range, but is there any particular problem with using it at home?
They are wondering if there is any impact on other devices when the transmit power is increased to support Extended Range.
I thought that CYBLE-212006-01 has no particular problem since it has already obtained FCC, MIC, CE, and other certifications.
Am I correct in my thinking? Also, is there anything I should be aware of?
T. Shibutani
AIROC™ Bluetooth
- Email to a Friend
There will not be any problem by using this module in home and it will also will not affect any other devices.
Thanks & Regards
Pratiksha V
- Email to a Friend
Thanks & Regards
Pratiksha V
