tado_4837711
25 sign-ins 10 sign-ins 5 replies posted
Hi, there
We plan to use a CYBT-343026-EVAL  as a dual mode bluetooth controller. We have tested the CYBT-343026-EVAL under Linux (using btattach) and Windows(using Cybluetool), it works as expected.
The next step is using a third-party MCU (NUCELO-429ZI STM32F429) working as bluetooth Host connected with CYBT-343026-EVAL through HCI UART
Currently, the Host can send commands (Reset),  unfortunately the CYBT-343026-EVAL gives no response.
We are considering it might caused by the Host Side improper configuration, or the  CYBT-343026-EVAL does not enter the HCI Mode.
So we prefer to add some indicator that the CYBT-343026-EVAL successfully entered the HCI Mode for easy debugging.
Is there any guide to do so?
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
Sorry, the working mode of the device is hardware related. We can't control the GPIO in HCI mode.
You may check the HCI mode by sending HCI Reset command. If the device has no response, then the device is not in HCI mode.
Owen_Zhang123
tado_4837711
Got it. We have fixed it
