Hi~
I received PIN Code feature was not supported with latest spec before.
But our customer asked the relevant documentation for persuading an end customer.
Is there any documentation for above?
Many Thanks
BRs
Daniel Lim
Solved: Re: CYW20719 Bluetooth Pairing with PIN Code meth... - Infineon Developer Community
AIROC™ Bluetooth
Hello @SeunghanLim
The PIN code feature is not supported with latest spec. It is not a safe way for the connection. And it is against the spec to add the feature. Hence we can't promote any discussion on the same in Community platform.
Hope you understand.
Anjana
Hello @SeunghanLim
Anjana
Okay I understood.
I found that issue was discussed in other platform by googling.
Anyway Thanks.
BRs
