I am using the API dll.
Looking for a way to imitate the disconnect event in CySmart1.3 , when the peer device disconnects.
Similar question: https://community.infineon.com/t5/PSoC-4/Using-CySmart-API-how-can-I-detect-the-loss-of-a-connection...
[16:25:18:896] : 'Connection Terminated Notification' event received
[16:25:18:896] : Reason: CONNECTION_TIMEOUT
I can't find a way in the API callbacks that gives such an event.
In the API doc's I see some function that may help:
How can I use it? Is there a callback I can listen to? Other way to implement?
Thanks!
Please can you check with OnConnected (CyConnectResult result, CyStatus status) Public Member Function from CySmart API Reference Guide because CyStatus enum has BLE_ERROR_HCI_CONNECTION_TIMEOUT.
Thanks & Regards
Pratiksha V
Have you gone through "CySmart Subsystem Overview" and "API Design" section in the CySmart API Reference Guide .you can also refer the Page no 54 and 21 for various callbacks and error codes.
Please let me know if this helps
Pratiksha V
Thanks, I went through the reference guide, but I have a question:
Is L2CAP layer connection created (automatically) when using the connect method via CyBleMgr (GAP) ?
Will I get callbacks from L2CAP layer (OnChannelDisconnectIndication callback) when connected via CyBleMgr (GAP)?
I am trying to get some indication that the peer device has disconnected from me.
if someone did it and can propose a method it would be of great help!
Thanks & Regards
Pratiksha V
