AIROC™ Bluetooth Forum Discussions
GrCa_1363456
First comment on KBA First comment on blog 250 sign-ins
What are the specific differences between CYW20732S and CYW20736S or CYW20737S?
For a product designed for CYW20737S, what changes would be required to use a CYW20732S?
Note that as of 9/21/2021, there are 260 CYW20732S parts available in distribution. There are no CYW20737S or CYW20736S parts currently available.
Note these parts are "identical from a HW perspective" according to Community Post What is going on with packages???
Data Sheet for CYW20732S @ ???
Data Sheet for CYW20736S @ https://www.cypress.com/documentation/datasheets/cyw20736s-bluetooth-low-energy-system-package-sip-m...
Data Sheet for CYW20737S @ https://www.cypress.com/documentation/datasheets/cyw20737s-bluetooth-low-energy-system-package-sip-m...
Greg
MichaelF_56
Hi Greg,
The 20732x was EOL'd, so don't start a new design with that device.
Remember also that the 20732 used different FW that was only supported by the older versions of the WICED Smart SDK
The 20736/37 use the latest version of that SDK and support the newer FW.
The WICED Smart SDK is no longer available here in the community, so you will need to create an internal support ticket to obtain.
MichaelF_56
Hi Greg,
