AIROC™ Bluetooth Forum Discussions
bemale
100 sign-ins 50 sign-ins 25 sign-ins
Is there any I2C example code using GPIO? I used all of pins related I2C interface on CYW920706 for I2S audio path, so need to use GPIOs for I2C interface. think there are some example codes for this application.
Could you please help this stuff?
Thanks for your reply in advance.
bemale
Hi SheetalJ,
Two examples you mentioned are I2C example using dedicated I2C interface not for using GPIO I asked.
I've made my code using GPIO and checked worked it.
Anyway, thanks for your attention and I'll ask you later if there is any problem in my code.
Ekta
250 solutions authored 100 likes received 250 sign-ins
Hello @bemale ,
Can you please let me know which device are you using? Are you using one of the cypress development boards  for programming your application?
I see in the labels you have mentioned PSoC General query while in the message it is mentioned that the device is CYW920706.
Best Regards
Ekta
bemale
Yep. CYW920706 is right.
bemale
Hi SheetalJ,
