hi Cypress:
Do you have any application note of How to use BT/BLE to realize the multislave-multimaster one? tks;
What's the role for CYW20706, master or slave?
The following demo is one master multi slave: https://community.infineon.com/t5/Resource-Library/CYW20706-BLE-Secure-Data-Hub/ta-p/246351
If you need one slave multi master, you can just re-start the adv in the connection up event, then the device can be discovered by other client again. You also need to change the parameter server_max_links in wiced_bt_cfg.h for multi connection.
Have a look at https://www.cypress.com/documentation/code-examples/ce223508-psoc-6-mcu-implementing-ble-multi-conne... which PSoC6 BLE is on Creator.
Which device are you using?
hi Owen:
if we use cyw20706, can we have demo code for it ?
