I want to interface my CYW20706 to a linear PCM codec device in slave mode.
I have been working with the CYW20706 for my intercom project for a while now. I have been able to use the sample HSP-Audio Gateway code using the Modulus ToolBox to initiate a connection with my Bluetooth headset.
I connected my CYW20706 to an I2S/PCM audio codec (Digilent Pmod I2S2) and I successfully managed to achieve the desired bidirectional audio communication. However, all along, the CYW20706 has been configured as the PCM master providing the required Serial clock/PCM_BCLK and Left-Right Clock/PCM_SYNC to the slave PCM audio codec.
I want to configure the CYW20706 in HFP-Audio Gateway as a PCM/I2S slave so that it can receive the PCM_BCLK and PCM_SYNC clocks from the PCM audio codec acting as the PCM master.
I have referred to the link below and it hasn't been helpful
https://community.infineon.com/t5/Resource-Library/PCM-I2S-Clock-setting-in-CYW20706/ta-p/246335
Mark
I simply tested the API on my side like follows. But I didn't see the error.
Please try the following API located in wiced_hal_pcm.h:
typedef struct{
wiced_hal_i2spcm_path_t mode; /* 0:I2S, 1:PCM*/
wiced_hal_i2spcm_role_t role; /* I2S/PCM interface role: 0: slave; 1: master */
wiced_hal_pcm_param_t pcm_param; /* Configure pcm1 param here*/
}wiced_hal_pcm_config_t;
* Function wiced_hal_set_pcm_config
* To set the pcm configuration parameter
* @param[in] pcm_config : strucure pointer
* @return void
void wiced_hal_set_pcm_config (wiced_hal_pcm_config_t *pcm_config);
Hi Owen,
Thanks for the reply.
I found the API now I want to know exactly how I would implement it.
Mark
Please call the API in hfp_ag.c file during the hfp_ag_startup.
This is what I've done and these are the errors that I got
May you please help suggesting a way to get rid of the errors and have the API working
Thanks for the assistance, I got it to work perfectly
