AIROC™ Bluetooth Forum Discussions
dheeraj20231
10 replies posted 10 sign-ins 5 replies posted
I am using custom hardware and I perfectly run HID LE Remote example from CYBLE 303472 EVAL M2B BSP.
I also get input from keypad and send to the HID over BLE.
Now I want to disable keypad scanning in runtime for low power consumption and when I get GPIO interrupt  that I want to enable keypad scanning.
 I Try call below function in runtime (one by one and together)
wiced_hal_keyscan_turnOff();
kscan_shutdown();
But keypad scanning is still running.
Sven_Wang
50 replies posted 10 solutions authored 50 sign-ins
Hi @dheeraj20231
Could you reproduce it in the CYBLE 303472 EVAL M2B rather than custom hardware?
Sven
dheeraj20231
Hi, I also test same thing by CYBLE 303472 EVAL M2B evalution kit and this is not working.
I Tried with GPIO pull up disable and enable in runtime.
After Disable pull by following line, my keypad is not send data om terminal, that means it was disable. and than enable it was working again.
Disable :wiced_hal_gpio_configure_pin(WICED_P00, GPIO_PULL_UP_DOWN_NONE, GPIO_PIN_OUTPUT_LOW);
Enable: wiced_hal_gpio_configure_pin(WICED_P00, GPIO_PULL_UP, GPIO_PIN_OUTPUT_HIGH);
But I don't  know why below pre defined function is not working
kscan_shutdown();
Sven_Wang
Hi @dheeraj20231
You need to disable interrupts at the same time.
    kscan_shutdown();
        // Disable Interrupts
    wiced_hal_mia_enable_mia_interrupt(FALSE);
    wiced_hal_mia_enable_lhl_interrupt(FALSE);
Like the APP_shutdown.
Even so, I was confused why you want to save energy at the runtime. The electric current cost should be lower than MCU and RF parts.
Sven
Hi Sven,
Thanks for the reply. I tried above solution.
--------------For disable keypad  -------------------------
    kscan_shutdown();
--------------For Enable keypad  -------------------------
    wiced_hal_mia_enable_mia_interrupt(TRUE);
    wiced_hal_mia_enable_lhl_interrupt(TRUE);
But my keypad is not disable , it was send data to HID.
