I am using custom hardware and I perfectly run HID LE Remote example from CYBLE 303472 EVAL M2B BSP.
I also get input from keypad and send to the HID over BLE.
Now I want to disable keypad scanning in runtime for low power consumption and when I get GPIO interrupt that I want to enable keypad scanning.
I Try call below function in runtime (one by one and together)
wiced_hal_keyscan_turnOff();
kscan_shutdown();
But keypad scanning is still running.
Hi dheeraj
Sorry for replying so late.
kscan_shutdown() was used for low battery and should disable the interrupt to complete the process. I saw you enabled the interrupt again. The key scan should not cost much current, could you please share your occupied current and excepted current?
BR
Sven
Could you reproduce it in the CYBLE 303472 EVAL M2B rather than custom hardware?
Sven
Hi, I also test same thing by CYBLE 303472 EVAL M2B evalution kit and this is not working.
I Tried with GPIO pull up disable and enable in runtime.
After Disable pull by following line, my keypad is not send data om terminal, that means it was disable. and than enable it was working again.
Disable :wiced_hal_gpio_configure_pin(WICED_P00, GPIO_PULL_UP_DOWN_NONE, GPIO_PIN_OUTPUT_LOW);
Enable: wiced_hal_gpio_configure_pin(WICED_P00, GPIO_PULL_UP, GPIO_PIN_OUTPUT_HIGH);
But I don't know why below pre defined function is not working
kscan_shutdown();
You need to disable interrupts at the same time.
Hi Sven,
Thanks for the reply. I tried above solution.
--------------For disable keypad -------------------------
Hi dheeraj
BR
Sven
