- Email to a Friend
Hi, Sir/Ms.,
Hardware: CYW20706 + UART_HCI_Interface + SPI Flash
The application code: xxx.hex
Now I want to download my application code into SPI Flash. Can you tell me what tools I need, including the software and programmer.
- Email to a Friend
Hello @szchen2006
Programming Tools
1.Cypress Programmer : https://www.cypress.com/products/psoc-programming-solutions
2. CyBluetool : https://community.infineon.com/t5/Public-Archive/CyBluetool-User-s-Guide/m-p/256195
3. if you want to develop your own programming software , you can refer to the download procedure and commands described here: https://infineon.github.io/btsdk-docs/BT-SDK/WICED-HCI-Firmware-Download.pdf
Anjana
- Email to a Friend
Hello @szchen2006
Programming Tools
Anjana
- Email to a Friend
Hi, Anjana,
Thank you for your quick response,
I have one more question for you:
Here I mean I want to download my application code into the extra SPI Flash, not ROM of CYW20706.
Based on you answer, MiniProg4, or CyBluetool can help me to finish the task, right?
- Email to a Friend
只是好奇:你为什么要把application code download到外部的SPI Flash(具体什么型号Flash?)呢?
- Email to a Friend
你不知道吗?赶紧看看CYW20706的芯片手册,你很快就会明白的。
- Email to a Friend
Hi, Anjana,
I need your answer.
- Email to a Friend
- Email to a Friend
hello @szchen2006
Seems like the file paths are not valid.
I think you can use Cypress programmer https://www.cypress.com/products/psoc-programming-solutions . It is more easy. You just need to provide hex file.
Anjana
- Email to a Friend
Hi, Anjana,
I am sure all path is valid. Can you try this at your side?
- Email to a Friend
Hi, Anjana,
I have no MiniProg4 in my hands.
Can you tell me other ways to solve this.
- Email to a Friend
Hi, Anjana,
I have one question for you: can I use CYW920706WCDEVAL to program the extra FLASH?
- Email to a Friend
HI @szchen2006
For programming the CYW20706 device from a PC application, you may need USB-UART bridge converter setup.
If you don't have the setup, then you can use the 20706 EVAL board same on 20706 EVAL. For that you may have to tape out wires from HCI UART header on the eval board and use it with the HCI UART pins on your custom board. Header connections can be checked on EVAL board ( https://www.infineon.com/cms/en/product/evaluation-boards/cyw920706wcdeval/ )
Anjana
