Hi Cy,
this post is an extensions of previous "Regarding a size of "audio_codec_buffer_size" when FOTA application is combined in audo_headset app" post.
I think it will be solved if I move some code to sflash area from sram.
However, I couldn't find a way to modify linker file for it and linker descriptor is generated automatically in CYW20706.
Is there any way to use memory resource as I want in CYW20706?
I couldn't understand the solution you have mentioned. You are downloading your application to the flash memory, right? Then what section of code you want to move from ram to flash?
Anyway, I don't think it is possible to modify the linker.
-Dheeraj
-Dheeraj
