I want to show sample application to customer with BT classic keyboard connection.
I am trying to make it with CYW920706WCDEVAL and CYBT343026-01
Is any sample application which you can suggetst?
- BT HID. Keyboard
I am afraid we do not have such example available then. Only ble hid example are available here- https://github.com/Infineon/mtb-examples-CYW920735Q60EVB-01-btsdk-hid
Hi Daniel,
Unfortunately there is no code example for HID using ModusToolbox using CYW20706. If it helps, you can use https://github.com/Infineon/mtb-example-btsdk-hid-ble-remote using CYW20735 chip.
But this sample application is for the BLE solution.
I need BT classic sample appl.
Is any other sample appl for it?
