I would like to know if is possible to access the Firmware (read/write/dump)? I have an eval kit CYW920706WCDEVAL.
Calin
PSoC Creator & Designer Software
Hi @conofrei_485418 ,
Are you referring to ROM Firmware? Unfortunately customer do not have access to ROM FW to perform any read/write activity.
Calin,
I believe you placed this question in the wrong forum. This forum "PSoC Creator & Designer Software" is for question regarding Creator and Designer IDEs.
The CYW920706WCDEVAL kit which uses the CYW20706 IC is only available to be developed using the WICED Studio IDE. See https://www.cypress.com/documentation/development-kitsboards/cyw920706wcdeval-evaluation-kit
The WICED Studio forums are located at: https://community.cypress.com/t5/WICED-Studio/ct-p/WicedStudio
