Hello community
I am quite new to working with Bluetooth Low Energy and now I am having some difficulties.
I want to connect with the standard profile (CYSPP) and the Acknowledged Data Characteristic Service. However, I never get a response from the Bluetooth module (see screenshot). It works with other apps from the Android Store, but not with mine. If anyone has any suggestions on what else I can try, I am of course open to it.
AIROC™ Bluetooth
Hi @AnjanaM_61
Thank you for your input.
In the meantime the problem has been solved, I have read all the packets that came from the Bluetooth module. I had to read only the ones with content and so it works.
Thanks a lot.
Timon
Hello @Timon
Can you please confirm which IFX BTBLE module you are using?
Hope you followed the steps mentioned in Ez-Serial platform guide for particular module available here: https://www.infineon.com/cms/en/design-support/software/device-driver-libraries/airoc-wi-fi-bluetoot...
Anjana
Hi @AnjanaM_61
Thanks a lot.
Timon
