- Email to a Friend
I tried to connect CYW920736M2EVB-01 by USB UART.
but it was failed.
I searched to solve problems at this community what i had
and tried to follow solution. it was also failed.
I don't know what is problem.
Please give me solutions.
Error message is below
Started by GNU MCU Eclipse
Open On-Chip Debugger 0.11.0+dev-4.3.0.1746 (2021-09-16-07:59)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 10000 kHz
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
cortex_m reset_config sysresetreq
force hard breakpoints
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf155, serial=1C14177E01051400
Info : CMSIS-DAP: SWD supported
Info : CMSIS-DAP: Atomic commands supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.30.1155
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 3.316 V
Info : clock speed 10000 kHz
Error: Error connecting DP: cannot read IDR
Error: DAP 'CYW20819A1.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
Info : CYW20819A1.dap: powering down debug domain...
Warn : Failed to power down Debug Domains
- Email to a Friend
If you are downloading any application, please on the program button from the Quick Panel options.
If you are trying to use the debugger, then, please click on the Attach_Jlink or Attach_Kitprog3_Miniprog4. Please check the below document for more details for source code level debugging.
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/AIROC-Hardware-Debugging.pdf
-Dheeraj.P.K
- Email to a Friend
Thanks for your reply.
Problem is about disconnecting serial port when i try to download application at ModusToolbox
Error message is "Serial port not detected... & Download failed"
I don't know why it is caused bacause it was not problem until last week.
Of course i checked documentations regarding set-up to solve problems but it was failed.
- Email to a Friend
Hello Dheeraj.PK,
I have the same issue with my CYW920721M2EVK-02. The board programmed without issues. Seeing these log messages after launching "[code example name] Attach_KitProg3_MiniProg4"
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf166, serial=180804B803260400
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 1 nTRST = 0 nRESET = 1
Info : VTarget = 3.312 V
Error: DAP 'CYW20721B2.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
Info : CYW20721B2.dap: powering down debug domain...
