Hello everybody,
Does any one really know why this error pops up: Cy_BLE_GAP_GenerateKeys returns API Error: 0x160004 CY_BLE_ERROR_INSUFFICIENT_RESOURCES ?
In the documentation we can find "If BLE Stack resources are unavailable.". What resources is this line referring too? We use an app with OTA over BLE and everything is fine expect there are moments when we received this error.
Any hints would be really appreciated!
Marian
PSoC 6 MCU
Cy_BLE_GAP_GenerateKeys can return CY_BLE_ERROR_INSUFFICIENT_RESOURCES if HCI commands queue is FULL, so BLE stack can't allocate resource for this command.
Before calling Cy_BLE_GAP_GenerateKeys, if any other BLE functions are called without waiting the response (by event) then this error might occurs.
Please make sure that Cy_BLE_ProcessEvent function is called at regular intervals of time (refer to documentation for this function). Also, set the BLESS priority to the highest(i.e., priority should be 0).
If possible, please share your project for checking at our end.
P Yugandhar.
P Yugandhar.
Thanks for the fast response. Due to some problems with Infineon change password issues I was not able to accept the answer as a solution earlier. Indeed we called Cy_BLE_GAP_GenerateKeys based on event and the queue was full by that time. We add a cyclic processing thread for this and now the keys are generated correctly.
Marian
