We were using the BT121 bluetooth module by Silicon Labs for our application. Our Design Team Has suggested CYBT-353027-02 to replace the SiLabs part.
BT121 datasheet has mentioned 1 x BR/EDR + 6 x BLE connections simultaneously. While we couldnt find any such particular data in CYBT-353027-02 datasheet.
Can you please share how many simultaneous connections are possible with CYBT-353027-02, BR & BLE in detail.
AIROC™ Bluetooth
Hi @juan-HC ,
Our module supports 8 BLE connections simultaneously. Although for BR, the number of simultaneous connections depend on the profile you are implementing. You can check out our audio watch code example: https://github.com/Infineon/mtb-example-btsdk-audio-watch for an idea on how BR profiles are implemented.
Thanks and regards,
Advait Kulkarni.
Hi @juan-HC ,
Thanks and regards,
Advait Kulkarni.
Thanks Advait,
BR we will be using only 1 connection.
