I am using a CYBT343026 module, controlling it via EZ-Serial.
I use bt_start_inquiry to find BT/EDR devices. I see that some devices return both bt_inquiry_result and bt_name_result while some return only the former, providing no device name.
When I enumerate the same devices with my PC/Phone I see their names. I suppose that the PC/Phone sends LMP_name_req requests for those devices.
How can I do the same via Ez-Serial?
I tried bt_query_name, but this seem to work only for devices that already return a valid name.
Is there a way to retrieve device names for BT/EDR devices that don't expose it in their inquiry reply but just on request?
Thank you in advance for your support.
I tested with FW 1.2.27 and 1.2.29.
I checked it internally. The bt_query_name also uses the inquiry process and returns the name during the inquiry.
We will check it and update the process in the next release of the EZ-Serial FW.
