I tried whitelist feature in two CYBT353027-02 EVB (v1.2.29), but I could not see an expected behavior.
1st, in Peripheral side, set whitelist filter policy (SSP,F=01)
and regist Bluetooth address of Central side in whitelist (/WLA,A=DCD45412D3D1).
Next, in Central side,
execute the Scan (/S), then the peripheral side is appeared in scan list. Is this behavior correct?
Execute the Connection (/C), then the connection is successful. is this behavior correct?
If above operation is not appropriate, please let me know right operation.
Yasui @ TED
Hi @TaYa_4777276 ,
Whitelisting feature is not supported for filtering the advertisement packets. This is documented in the gap_start_scan() section of the user guide.
I have filed an internal request for this. Thanks for your interest with our products.
Bragadeesh
