Jul 05, 2021
05:18 AM
Jul 05, 2021
05:18 AM
I am using BLE module with the GATT mode and i am asking how can i change the packet size more than the default where it is only 20 byte per packet while i used " p_cyspp_set_packetization "
Labels
Wireless
06:59 PM
Jul 07, 2021
06:59 PM
You can use the API Command ".CYSPPSK" to set the length to what you want. For example, ".CYSPPSK, L=20" will set the length to 32 bytes. Please remember you need to add a carriage return at then end of the command.
06:59 PM
Jul 07, 2021
06:59 PM
