I am using CYBT-343026-EVAL as controller side and program mtb-example-btsdk-empty by ModusToolBox2.3.
When I check the supported HCI command with CyBluetool, the commands defined in 5.0 and 5.2, like "LE_Set_Extended_Advertising_Parameters" or "LE_Set_CIG_Parameters", are all returned "Unknown HCI Command".
I also check the supported HCI commands by sending "Read_Local_Supported_Commands", the contents displayed doesn't include such commands.
Questions:
1. Does CYBT-343026-01 support BT5.2?If supported, is there a matched BTSDK app which can be programmed to use BT5.2 features?
2. Does ModusToolBox2.3 with BTSDK 3.0 support BT5.0? The HCI command defined in BT5.0 like "LE_Set_Extended_Advertising_Parameters" also return "Unknown HCI Command".
Wireless
Hi @xin10pan ,
CYBT-343026-01 is BT 5.0 certified and supports all features of BT 4.2 (LE secure connections, DPLE and LE privacy). It does not support any of the features of BT 5.0 (2 Mbps PHY, Advertisement extensions etc.) . I hope this answers your question.
Currently, none of our broad market chips support LE advertisement extensions feature. Please contact your local sales representative or marketing team for further information.
Bragadeesh
Hi @xin10pan ,
Bragadeesh
