wenchilo
Level 4
Level 4
First like received 25 replies posted 25 sign-ins
Hi, I want to implement iAP2 in CYBT343026,  I am using mtb-example-btsdk-pro-iap2 , but I am not sure if it support CYBT-343026 cause I can't search it from iphone  and the log are all garbled. Could you tell me if iAP2 is capable to implement in CYBT-343026. If yes, how to make it work.
Charles_Lai
10 questions asked 250 replies posted 100 solutions authored
mtb-example-btsdk-pro-iap2 is not a publicly distributed example of IFX products. You should contact your local sales representatives for internal support and queries.
iAP2 needs your own certificate as well. You can get the certificate from Apple. See:
https://developer.apple.com/accessories/Accessory-Design-Guidelines.pdf
Charles_Lai
