AIROC™ Bluetooth Forum Discussions
JiZh_4619191
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
What is the RF Antenna Port(PIN18) output resistance of Cyw20719B2KUMLG?
Best regards.
Jian
SheetalJ
Hi Jian,
Following is the response from our team:
The RF FE that connects to 20719's RF port should match to 50-ohm system and usually antenna input is non-50ohm so definitely requires matching to ensure that there is no power loss to the antenna.
SheetalJ
Hi Jian,
I am checking this internally with our RF team, will update you soon.
SheetalJ
Hi Jian,
I couldn't find the exact value but usually it is 50 ohm.
SheetalJ
Hi Jian,
JiZh_4619191
Level 4
Level 4
Thanks a lot!
