I'd like to ask for opinion/advise on several issues. I will give you the context first:
I am developing an application using the CYW20719B2 in Modustoolbox as officially suggested by Infineon. I am looking into doing a test production series, thus I will need at least several dozens of the MCUs. Unfortunately I cannot find any supply of this chip anywhere nor any expected date of new stock.. However I can see that CYW20719B1 MCUs have still quite high stock availability. Therefore I am considering using the CYW20719B1 in the meantime and then go with the CYW20719B2 when available. I understand that CYW20719B1 is not supported in Modustoolbox and is only supported in WICED Studio. Based on this I would like to ask the following:
1) Is there any official/unofficial way to add the CYW20719B1 target into the Modustoolbox? If so could you please give me some leads where to begin?
2) Is there a way to port the application from Modustoolbox back to WICED studio? Especially how to go about the generated files (COMPONENT_btstack..)?
3) By any chance is there somewhere some available stock of CYW20719B2 MCUs that I am not aware of? Or at least does anyone know about when we can expect CYW20719B2 to be available?
I understand that official advise is not to go back to CYW20719B1, however I do not see any better solution at this time. If you can give me any other advise that I missed on how to go about the current situation I would be very grateful.
Thank you.
Hello @jakub
It is not recommended to use CYW20719B1. CYW20719B2 should be available. I suggest you to contact our local sales & FAE.
A: It is not possible
A: It is not directly compatible, but you can refer to the application code flow and do the same implementation in WICED SDK
A: Please contact our local sales & FAE.
Anjana
Hello @jakub
Anjana
