AIROC™ Bluetooth Forum Discussions
HiNa_2357246
5 likes given 50 replies posted First like given
There seems to be no community Blog posts about CVE-2022-25836 but would enabling "LE Secure Connections only" should suffice to counter this vulnerability?
advait_kulkarni
50 solutions authored 10 likes received 100 sign-ins
Hi @HiNa_2357246 ,
This CVE does not affect our products. You can search on our community for "CVE" or "Security Bulletin" and you will see the CVEs we have fixed in our products, for example: https://community.infineon.com/t5/Blogs/Security-Bulletin-Public-Statement-on-Bluetooth-SIG-Member-S...  If any CVE is not found there then its probably because they do not affect our products.
For your case, LE secure with MITM authenticated pairing is to prevent this vulnerability. You need to set these capabilities in the BTM_PAIRING_IO_CAPABILITIES_BLE_REQUEST_EVT.
Thanks and regards,
Advait Kulkarni
wasu
5 solutions authored 10 replies posted 10 questions asked
"LE Secure Connections only" together with "authenticated pairing" will prevent this issue.
"LE Secure Connections only" will encrypt data to protect against eavesdroppings.
"authenticated pairing" will protect against MITM attacks.
advait_kulkarni
Hi @HiNa_2357246 ,
Thanks and regards,
Advait Kulkarni
