May 07, 2021
08:20 PM
May 07, 2021
08:20 PM
Hello:
Briefly,we are now using CYBT_343026_EVAL (CYW20706) as a dual-mode bluetooth controller.
When executing the GAP/CONN/CPUP/BV-08-C (Connection Parameter Update Procedure) test case with PTS, the case failed because of error response (LL_REJECT_IND).
The blue color marked LL_CONNCTION_PARAM_REQ is initiated by MASTER which is PTS
The read color marker LL_REJECT_IND is responded by SLAVE which is CYBT_343026_EVAL
Please help me check with this issue?
Labels
Wireless
03:15 AM
May 10, 2021
03:15 AM
May 10, 2021
10:17 PM
May 10, 2021
10:17 PM
Is there any updating?
